Cleaning our Govee products is something we all dread, but it’s necessary to keep them in top shape! Today, I want to share my experience with cleaning the Govee diffuser, as well as some tips that might help others.
First off, unplug the diffuser from the wall. Then, take off the lid—it just pops on and off. Next, remove the ‘spoon’ and set it aside. I usually put a little hot water inside the tank and use the brush that came with the diffuser to scrub the bottom hole. This ensures that any buildup is removed.
For those of you who might be struggling with getting your LED lights to connect to Wi-Fi, here’s a tip: make sure the lights are within range of your router and that the Wi-Fi signal is strong. If you’re still having trouble, try resetting the lights and re-pairing them.
Cleaning might not be the most exciting task, but it’s essential for maintaining the functionality and longevity of our smart devices. Let me know if you have any other tips or tricks for keeping your Govee products clean and running smoothly!
