Combining with smart light automations
I have an aqara smart lock
Is there a way to get the hallway lights to turn on automatically after I unlock the door?
@mxm100 Hey there! Absolutely, this is one of the classic smart home automations that works great with Aqara gear. Depending on which lock model you have, you can set up an automation in the Aqara Home app where unlocking the door triggers your hallway lights to turn on.
For example, with the Smart Door Lock K100, there’s a built-in recommended automation: when you unlock with fingerprint/password/NFC at a specified time and the room is dark, the lights come on automatically using a light sensor and wall switch.
More broadly, the general approach works across several Aqara locks—common “IF” triggers include “unlock the door,” “open the door from outside,” or “open door with assigned fingerprint,” which you can pair with “turn on light” as the action[“content_id:6”]. The exact automation options vary by lock model, so check what’s available under your specific lock’s automation settings.
For a simple setup, you’ll typically need:
  • Your Aqara smart lock
  • An Aqara hub (like Hub M2)
  • Smart lights or a wall switch/plug to control your hallway lights
If you want to get fancier, you could add conditions like time of day or brightness levels so it only fires when it’s actually dark.
What lock model are you working with? That’ll help narrow down the exact triggers available to you.
