Configuring Google Assistant for Multiple Locations: A Comprehensive Guide
As a homeowner who values seamless integration across all aspects of my life, I’ve always been fascinated by the potential of smart home technology. However, one challenge I’ve faced is configuring Google Assistant to work across multiple locations—specifically, my primary residence and my vacation home. After spending considerable time researching and experimenting, I’ve discovered a few key insights and solutions that I’d like to share with the community.
For those unfamiliar, Google Assistant allows users to set up multiple “Home” locations within the Google Home app. This feature is incredibly useful for individuals who manage multiple properties or have different living spaces. However, the process of syncing these locations with Home Assistant (HA) can be quite complex. In my setup, I have HA installed at my primary residence, and I wanted to ensure that all my devices are correctly associated with the appropriate “Home” location in Google Assistant.
One of the main issues I encountered was that when I synced my devices, they weren’t automatically assigned to the correct “Home” location. Instead, they appeared without any specific location or room designation. This meant that I had to manually adjust each device’s settings within the Google Home app, which was time-consuming and frustrating. To streamline this process, I explored various configuration options within HA’s Google Assistant integration.
I found that by carefully configuring the entity_config section in my Google Assistant settings, I could assign specific devices to their respective “Home” locations. This involved mapping each entity to the correct room and ensuring that the necessary attributes were included. For example, by specifying the room attribute in the entity configuration, I could ensure that my devices were correctly associated with their designated spaces.
Another critical aspect was ensuring that the expose_by_default setting was configured correctly. By default, this setting is enabled, which means that all devices are exposed to Google Assistant unless explicitly excluded. However, in my case, I wanted to have more granular control over which devices were exposed and how they were presented. This required careful tweaking of the exposed_domains and entity_config sections to ensure that only the relevant devices were exposed and that they were correctly labeled.
One thing that I discovered during this process was the importance of consistency in naming conventions. By using consistent and descriptive names for my devices and rooms, I was able to make the configuration process much smoother. For example, naming my devices with prefixes like Front_Hall_ or Bedroom_ made it easier to identify and configure them within the Google Assistant settings.
I also found that leveraging the aliases feature within the entity_config section was incredibly helpful. By assigning aliases to my devices, I could ensure that they were easily identifiable within the Google Home app. This was particularly useful for devices that had similar functions but were located in different rooms.
Another challenge I faced was ensuring that my devices were correctly grouped within Google Assistant. By default, Google Assistant groups devices based on their location and room, but I wanted to have more control over how these groups were formed. To achieve this, I carefully configured the group settings within HA to ensure that my devices were grouped in a way that made sense for my use case.
One thing that I wish Google Assistant supported is the ability to automatically assign devices to their correct “Home” location based on their IP address or geolocation data. However, I discovered that this isn’t currently possible, and manual configuration is required. Despite this limitation, I was able to find a workaround by using HA’s powerful automation capabilities to trigger location-based actions.
In conclusion, while configuring Google Assistant for multiple locations can be challenging, it’s definitely achievable with the right approach. By carefully configuring your HA settings, leveraging the entity_config section, and maintaining consistent naming conventions, you can ensure that your devices are correctly associated with their respective locations. I hope that this guide has been helpful and that others can benefit from my experiences. If anyone has any additional tips or insights, I’d love to hear them!
Happy automating!
