I’ve been working on setting up a GPIO LED for status indication on my DOIT DEVKIT board, and I thought I’d share my journey and solution with the community. This might help others who are facing similar challenges!
The Goal:
I wanted the GPIO2 LED to provide a simple “healthy” status indicator with a slow flash—0.1 seconds on, 2 seconds off. This would give me peace of mind knowing my device is operational without constant monitoring.
The Challenge:
Initially, I was overwhelmed by the variety of components and platforms listed in the documentation. I wasn’t sure whether I needed to use status_led, gpio, or something else entirely. After days of trial and error, I finally cracked it!
The Solution:
Here’s how I configured it in my ESPHome setup:
yaml
Inside your ESPHome configuration
gpio:
- pin: 2
mode: OUTPUT
on_off:- brightness: 100%
duration: 0.1s - brightness: 0%
duration: 2s
initial_state: OFF
- brightness: 100%
Key Takeaways:
- Simplicity is Key: I tried overcomplicating things with custom lambdas and templates, but sticking to the
gpioconfiguration made it straightforward. - Persistence Pays Off: It took multiple iterations and some debugging, but seeing that LED flash for the first time was incredibly satisfying!
- Community Support: If I had given up, I wouldn’t have discovered this elegant solution. Kudos to the ESPHome community for being so resourceful!
Why It Matters:
A reliable status indicator isn’t just a nice-to-have; it’s a crucial part of any IoT project. It reassures you that everything is running smoothly and helps in troubleshooting when things go south.
If anyone has further questions or improvements, feel free to reach out! Let’s keep the knowledge flowing! ![]()
