Configuring Motion Detectors for Light Automation
Hello everyone, I’m currently working on setting up a smart lighting system using two motion detectors in my living room. The idea is to have the lights turn on when either detector is triggered, which works perfectly. However, I’m encountering an issue where the lights don’t turn off when both detectors are no longer active. This is a bit frustrating as I want the lights to automatically adjust based on the room’s occupancy.I’ve configured the flow to turn the light on when either detector detects motion, but the problem arises when trying to turn it off. The flow uses an ‘All’ block, which should trigger the light to turn off only when both detectors are inactive. Unfortunately, this isn’t happening as expected. I’ve attached a screenshot of my flow setup for reference.I’ve tried adjusting the sensitivity settings on both detectors and ensuring they’re placed optimally, but the issue persists. I’m wondering if there’s a different approach to this setup or if there’s a specific configuration I might be missing. Perhaps using a different type of block or adjusting the logic within the flow could resolve this.I’m looking forward to hearing from the community and any suggestions or solutions you might have. Your insights would be greatly appreciated!
