Configuring Pushover in OpenHAB 3.2: A Step-by-Step Guide
I recently migrated from OpenHAB 2.5 to 3.2 and encountered some challenges with the Pushover binding. After some research and experimentation, I managed to get it working smoothly. Here’s a detailed breakdown of my experience and some tips for anyone else making the switch.
The Challenge
When I first tried to configure the Pushover binding in OpenHAB 3.2, I kept running into an error related to the sendHtmlMessage method. The error message indicated that this method wasn’t recognized, which was puzzling since it worked perfectly in the older version. I reached out to the community for help and found that this was a common issue during the migration.
The Solution
After some digging, I discovered that the method names had changed slightly in the newer version of the binding. Instead of sendHtmlMessage, I needed to use sendMessage with the appropriate parameters. Here’s how I adjusted my rule:
rule “Pushover Test”
when Item pushover received command
then
val actions = getActions(“pushover”, “pushover:pushover-account:account”)
switch(receivedCommand) {
case ON: {
actions.sendMessage(“Hello World!”, “openHAB3”, “priority”, “magic”)
logInfo(“PUSHOVER”, “–> on”)
case OFF: {
logInfo(“PUSHOVER”, “–> off”)
end
Key Takeaways
  1. Method Names Have Changed: In OpenHAB 3.2, sendHtmlMessage has been replaced with sendMessage. Make sure to update your rules accordingly.
  2. Parameter Order Matters: The parameters for sendMessage are in a specific order: message, title, priority, and sound. Double-check these to avoid errors.
  3. Community Support is Crucial: Don’t hesitate to reach out to the OpenHAB community forums. Someone else has likely encountered the same issue and can offer guidance.
Migrating to a new version of OpenHAB can be a bit daunting, but with patience and a little research, you can overcome most hurdles. The Pushover binding is a fantastic way to receive notifications, and getting it working in 3.2 opens up a whole new level of functionality. If you’re struggling with similar issues, I hope this guide helps you get back on track!
Happy automating! :rocket:
