Hey everyone! I wanted to share my experience and solution for connecting the GE 14284 Enbrighten Z-Wave Plus Smart Outdoor Switch to Hubitat. I’ve been using Wink before, and the process was pretty smooth there. However, when I decided to switch to Hubitat, I ran into some issues during the pairing process. I hope this guide helps others who might be facing similar challenges!
Step 1: Resetting the Device
First things first, I reset the switch to ensure it was in a clean state. I followed the manufacturer’s instructions to reset it, which involved holding down the on/off button for about 10 seconds until the LED started flashing. This step is crucial because it ensures the device is ready to pair with a new hub.
Step 2: Preparing Hubitat
I made sure my Hubitat ecosystem was up-to-date. I checked for any pending firmware updates for the Z-Wave controller and installed them if necessary. A stable and updated system is essential for smooth device integration.
Step 3: Initiating the Inclusion Process
On the Hubitat app, I navigated to the settings and initiated the Z-Wave inclusion process. I waited for the confirmation message indicating that Hubitat was ready to accept new devices.
Step 4: Pairing the Switch
With the inclusion process active, I held the on/off button on the GE switch until the LED started flashing rapidly. I kept the switch close to the Z-Wave hub to ensure a strong signal. After a few moments, I received a notification on my phone confirming that the device was successfully paired.
Step 5: Testing the Connection
I tested the switch by turning it on and off using the Hubitat app. Everything worked perfectly, and the LED on the switch responded as expected. I also checked the device status in the Hubitat dashboard to ensure it was communicating smoothly with the hub.
Step 6: Configuring the Device
To make the most of my new outdoor switch, I configured it within Hubitat to work seamlessly with my existing smart home setup. I set up routines and automations, such as turning the outdoor lights on at sunset or activating them when motion is detected.
While the initial pairing process was a bit tricky, taking it step by step and ensuring all components were properly configured made the difference. Hubitat’s support for Z-Wave devices is excellent, and having the GE 14284 integrated into my smart home setup has significantly enhanced my outdoor lighting control. If you’re considering adding this switch to your Hubitat ecosystem, give it a try—just be patient and methodical during the setup!
Happy smart home building everyone! ![]()
