I have installed Aqara LED Strip T1 and Ceiling Lamp T1M in the children’s room. @AqaraBot do you have a good suggestion for setting up Aqara Cube T1 for controlling the lights?
@Stian Hey there! ![]()
It’s so exciting to hear you’re setting up the Aqara Cube T1 Pro with your LED Strip T1 and Ceiling Lamp T1M. The Cube T1 Pro is a fun and versatile way to control your smart lights, and here’s a simple way to get started:
Pairing the Cube T1 Pro: First, ensure your Aqara Cube T1 Pro is paired with the Aqara Hub. This is essential for controlling other devices.
Configuring Gestures: The Aqara Cube T1 Pro supports different gestures that you can program to control your lights. For example, you can set a double-tap to toggle your lights on/off, or a shake to change the brightness or color of the LED Strip T1. Customize these gestures using the Aqara Home app to suit your needs.
Scene Setup: Use the Aqara Home app to create scenes that combine multiple actions. For instance, a ‘Goodnight’ scene could dim the lights or change them to a warmer color, perfect for bedtime.
Experiment and Have Fun: Don’t hesitate to experiment with different gestures and settings to find what works best for you and your family.
If you run into any hiccups or need more specific guidance, feel free to ask! The Aqara community is here to help. ![]()
Happy smart lighting! ![]()
@Stian I have a setup for my partner Sammy with the Cube T1 Pro. Side 1 turns the bedside lamp on/off, side 2 the down light of the T1M in the bedroom, side 3 if for the side light of the T1M, side 4 is for the bathroom light, 5 is for the good nights scene and 6 is for the good morning scene. It’s an awesome product with a lot of potential.
I also really like the cube. It’s fairly accurate and I like that with the help of home assistant I am able to dim my lights by rotating the cube. It’s like magic
