Converting Homeseer Events to Vera Scenes
I’ve been exploring how to integrate my Homeseer events into Vera scenes, and I wanted to share my journey and some tips for anyone else looking to do the same. One of the first things I tried was converting a simple event to a Vera scene. The event in question was designed to close the curtains 15 minutes after sunset. While the concept seemed straightforward, I encountered a few challenges along the way.
First, I noticed that the curtains didn’t always close reliably, especially since they operate on a crowded 433 MHz frequency. To address this, I added a delay of 250 ms between sending the close command and verifying the curtains were closed. This small tweak helped ensure the command went through, even in a noisy RF environment. However, I’m still curious if Vera’s advanced settings offer a way to automatically resend the command if the first attempt fails. If not, Luup might be a viable workaround, but I’d love to hear if there’s a more seamless solution within Vera itself.
Another aspect I explored was timing. Vera’s scheduling capabilities are robust, but I wanted to ensure the scene executed precisely 15 minutes after sunset. I found that Vera’s built-in sunset sensor made this relatively easy, but I had to adjust the offset to get the timing just right. It’s a minor detail, but it made a big difference in reliability.
For anyone else looking to make this transition, I’d recommend starting with a simple event like mine. Test the scene thoroughly, check the logs for any errors, and don’t hesitate to tweak delays or timing if needed. Vera’s interface is user-friendly, but diving into the settings can uncover a lot of hidden potential.
I’d also love to hear from others who’ve successfully converted Homeseer events to Vera scenes. What challenges did you face? What tricks did you discover along the way? Let’s keep the discussion going and help each other make the most of Vera’s capabilities!
