In a recent W600 thread, two valves were reported to recalibrate in the same minute. Looking at a temperature graph afterward, it can be hard to tell a calibration run from a valve move requested by the heating schedule.
Could Aqara Home log when each calibration started and ended, along with its outcome and trigger if the device knows it? Seeing that next to the setpoint and valve position, where available, would make it easier to line up events across two radiators and share a useful timeline with support.
I think that’s a neat idea. I would also be happy if I could see when the target temperature was changed.
It could help in diagnozing if heating is working properly, or if the schedule is ok.
Month ago my heating was running with a slightly lower temperature of water, so my schedule needed to be adjusted accordingly. Graph showing when the thermostat changed its target temp (and what it was) would help. Additionally, sometimes the temperature is adjusted manually by my family. I would also like to see when and what’s the target temperature to adjust my schedule.
Btw I use paired Aqara temperature sensors and I have cast iron radiators. When I set the temperature to 19.5°C (when the room temp is 18.5-19°C), the room heats up to 21°C because of the thermal inertia of cast iron. But month ago it was heating up to 20°C with the same configuration. So graph with the data I mentioned above would help me with adjusting my schedule.
The cast-iron example makes a good case for graphing the target and measured temperature together. A source label on each target change (schedule, manual adjustment, or automation, when known) would help distinguish a deliberate setpoint change from the room continuing to warm after the valve closes.
