Creating a Reliable INTRUDER ALERT Automation
Hey everyone! I’m really excited to share my journey of setting up an INTRUDER ALERT automation in my smart home. I’ve been a bit nervous about security, especially after a few close calls, so I decided to take matters into my own hands. Let me walk you through my thought process and the steps I took to make this work.First off, I wanted to create an automation that would trigger if someone tried to enter my garage after I’ve activated my bedtime scene. The bedtime scene turns off all the lights, so I figured it would be the perfect time to set up an alert if the garage door was opened. I’ve got a door sensor on my garage door, and I wanted to pair that with some smart lights to create a visible deterrent, plus send an emergency message to my phone.I started by drafting the automation in my mind. The trigger would be the garage door opening, but it needed to happen after the bedtime scene had been activated. I also wanted to make sure that both my partner and I were home before the automation would trigger, just to avoid any false alarms if one of us was out late.Here’s where I ran into my first challenge. The initial setup worked in theory, but in practice, there were some hiccups. For example, if the bedtime scene was activated and then deactivated before the garage door was opened, the automation wouldn’t trigger. It took me a bit of time to realize that I needed to adjust the conditions to account for the exact timing and ensure that the bedtime scene was still active when the garage door was opened.Another issue I faced was with the notifications. I set up the automation to send a message to both of our phones, but I noticed that sometimes the message would go through, and other times it wouldn’t. After some research, I found that adding a delay between the trigger and the action helped stabilize the notifications.Once I had the basics sorted out, I decided to add some extra layers of security. I included a scene that turns on all the lights in the house to startle anyone who might be trying to break in. I also set up a quick test to ensure that the lights would turn on reliably every time the automation was triggered.I must say, seeing everything come together was pretty satisfying. I tested the automation a few times manually to make sure it worked as expected, and it did! The lights turned on, and the notifications went through without any issues. It gave me a real sense of peace of mind knowing that my home was now better protected.Looking back, I think the key takeaway here is to test each component of your automation separately before putting them all together. That way, you can identify and fix any issues early on. Also, don’t be afraid to tweak your conditions and triggers as you go—automation can be a bit finicky, and sometimes it takes a few adjustments to get everything just right.If anyone has any questions or suggestions about setting up a similar automation, I’d love to hear from you! Let’s keep learning and improving our smart home setups together. :slight_smile:
