Creating a Smart Lighting System with Philips Hue and Styrbar Remote
I recently embarked on a project to enhance my home lighting setup using Philips Hue bulbs, an IKEA Styrbar remote, and the Hubitat ecosystem. The goal was to create a seamless and intuitive lighting experience that allows me to adjust both brightness and color temperature with ease. Here’s how I approached the setup and what I learned along the way.
Setup and Integration
  1. Connecting the Philips Hue Bridge: The first step was ensuring the Philips Hue bridge was properly integrated into my Hubitat setup. This involved pairing the bridge and testing basic controls through the Hue app and Hubitat interface.
  2. Pairing the Styrbar Remote: The Styrbar remote was paired directly with Hubitat, which worked without any issues. However, I quickly realized that while the remote could control brightness, it didn’t natively support color temperature adjustments—a feature I was eager to utilize.
  3. Exploring Button Controller Settings: I delved into the Button Controller app to see if I could configure the remote to cycle through different color temperatures. While I found ways to toggle colors and brightness, setting up a smooth transition or preset temperature states proved challenging.
Challenges and Solutions
  • Color Temperature Control: The remote’s ability to control color temperature wasn’t immediately obvious. After some experimentation, I discovered that while direct temperature control wasn’t supported, I could create preset scenes with specific color temperatures and cycle through them using the remote’s buttons.
  • Brightness and Color Transitions: I found that combining brightness adjustments with color transitions created a more dynamic lighting experience. This involved setting up custom scenes in Hubitat that paired specific brightness levels with corresponding color temperatures.
Tips for Others
  • Scene Creation: Create scenes for different lighting moods (e.g., warm for evenings, cool for task lighting). This allows you to switch between settings with a single button press.
  • Remote Configuration: Spend time exploring the Button Controller app’s settings. While it may not support every feature out of the box, there are creative ways to achieve your desired functionality.
  • Integration Testing: Test each component individually before attempting complex configurations. This helps identify any issues early in the process.
Conclusion
While I didn’t achieve the exact functionality I initially envisioned, the project taught me a lot about the capabilities of my lighting setup and the importance of creative problem-solving. The ability to adjust both brightness and color temperature has significantly improved my home’s lighting experience, and I’m excited to continue refining the system.
If anyone has tips or tricks for achieving smoother color temperature transitions, I’d love to hear them! Happy smart lighting!
