Hey everyone,
I wanted to share my success story about creating a virtual switch in OpenHAB. I’ve been using Domoticz before, and I was really impressed by how easy it was to create virtual switches there. When I switched to OpenHAB, I wasn’t sure how to replicate that functionality, but after some research and trial and error, I figured it out!
Here’s what I did:
Understanding the Need: I wanted a virtual switch that I could manually toggle from the Paper UI. This would allow me to control certain automations without needing a physical device.
Research: I looked into OpenHAB’s documentation and found that the
templatebinding was the way to go. Specifically, I needed to create abinary_sensorusing thetemplateplatform. -
Configuration: I added the following code to my
configuration.yamlfile:
yaml
binary_sensor:
- platform: template
sensors:
my_virtual_switch:
friendly_name: “My Virtual Switch”
value_template: >-
{% if is_state(‘binary_sensor.my_virtual_switch’, ‘on’) %}
off
{% else %}
on
{% endif %}
icon_template: >-
mdi:toggle-switch
{% else %}
mdi:toggle-switch-off
{% endif %}
Testing: After restarting OpenHAB, I went to the Paper UI and was thrilled to see my virtual switch appear! I could manually toggle it, and it updated the UI instantly.
Integration: I then integrated this virtual switch into my automations. For example, I set it up so that when I toggle the switch on, it turns on my living room lights and starts my favorite playlist.
I’m really happy with how this turned out. It’s a simple solution but makes a big difference in how I control my home automation setup. If anyone has questions or needs help setting something similar up, feel free to ask!
Cheers,
