Creative Solution for Window Sensors with Tiny Magnets
Hey everyone, I wanted to share a really clever solution I came up with for a problem I was having with my window sensors. I recently installed some contact sensors on my windows, but I ran into an issue where the gap on all my windows was too small to mount the sensors in a way that would detect an opening from both the bottom and top of the window. This was pretty frustrating because I really wanted the sensors to work reliably, but it seemed like a dead end at first.
After some brainstorming, I decided to try using some tiny magnets I found online. These magnets are super small—only 1/8 inch by 1/16 inch—but they turned out to be the perfect solution. I fixed them up on both sides of the window frame and attached the sensors to them. The best part is that they’re held in place with some double-sided tape, which keeps everything neat and secure.
Now, if someone tries to open the window from either the top or the bottom, the sensors catch it perfectly. I even went the extra mile and coated the magnets with some plasti dip to make them blend in better with the window frame. It’s a simple fix, but it makes a huge difference in terms of functionality and aesthetics.
I thought I’d share this in case anyone else is dealing with similar issues. Sometimes, the most effective solutions are the ones that seem a bit unconventional at first glance. If you’re struggling with sensor placement, I highly recommend giving this method a try—it’s affordable, easy to implement, and incredibly effective!
Cheers,
