Hello!
I apologize if this question has already been discussed, but I could not find it in the search.
I have a Smart Door Lock D100 Zigbee. Sometimes it gives an Mechanical error. Both at the entrance and at the exit.
When I exit, I press the button, but the lock does not open. Instead of turning white, the button turns red, and a warning sound plays. The lower unlock handle allows you to simply open the lock and exit.
When I enter, I use usually an RFID tag, but the lock does not open. Instead, a red light on the lock panel turns on and a warning sound is played.
A push notification about a mechanical error appears on the phone in the app. After a while, everything works.
Firmware Update 3.0.0_0017.
Tell me please what needs to be done to fix it. Should I lubricate the lock with machine oil? Should I call a professional to check the tightness of the bolts and the alignment of the lock tongue?
Tell me if you need details.
Thank you!
@sergeyfedorovdisk You’re welcome! It’s great to see you actively engaging with the community. If you encounter any other issues with your D100 lock or have more experiences to share in the future, don’t hesitate to post—we’re here to help and learn together
