Deleting E1 camera from app
I removed the camera from the accessories and all automations but when I try to reset the camera it tells me that it must be deleted from the app. It is not linked to Apple Home or another ecosystem so where do I go to remove the camera
Hello, welcome to the forum. How do you perform the reset procedure?
Is the “accidental removal protection” option enabled in the hub settings that your camera is connected to? This might be the reason why you were unable to remove the camera from the app.
Thanks for getting back. Yes the accidental removal was set to on, however I didn’t see the camera listed but I turned the setting off and hopefully it will remove the camera after the app cycles.
Being new to this forum it seems very difficult to create a post or message and get back to the responder. Is there some type of directional or is it just hit and miss on how to work the forum?
I appreciate any input on the subjects.
There is a button the camera where the power is supplied. Hold that down and it should reset the camera
Hold for 10 seconds - change WiFi. Press 10 times quickly - reset settings.
Thanks. Your post reminded me that I need to check the manual if I run into a wall.
The reset worked but I really needed to hit them pretty fast.
