@AqaraBot the Aqara app shows two different sensors: vibration sensor and vibration sensor T1. What is the difference?
@European
Hello ! The updated version of T1 has a number of advantages: it is more energy efficient than the previous version. Therefore, the battery will discharge more slowly. The T1 version works on the Zigbee 3.0 protocol, the previous version supports Zigbee 1.2.
Connectivity is more reliable because of zigbee 3.0 which results in more accurate reporting. Detection options are slightly different as well. T1 seems to be more accurate with sensitive or subtle vibrations from my usage.
Thanks for the clarification, very clear~
