Dimmer Switch H2 makes lamp flash when turning on
I ve installed an Aqara Dimmer Switch H2 (with a big and two small buttons) to control 6 lamps. I ve connected it to zigbee2mqtt and used claude to help me build the converter and external definition.
I think I was able to make it work for most of the features, but I m struggling with the lamps either flickering (forward mode), or flashing (reverse mode) when we turn the light on no matter which initial brighteness we are using. I played with min brightness, anti-flickering/quick mode, turn on ramps and others. Nothing made the lap control smoother.
Do you have any tip do diagnose and fix this?
