Hey everyone, I wanted to share a fun DIY project I recently completed using the Fibaro Smart Implant to monitor my buffer tank temperatures. This project has been a great learning experience and has added a nice touch to my home automation setup. Let me walk you through how I did it and the benefits I’ve noticed so far.### Project OverviewI have a 120-gallon buffer tank that serves my pellet and oil boilers. Monitoring its temperature is crucial for ensuring efficient heating and avoiding potential issues. I decided to use the Fibaro Smart Implant along with three DS18B20 temperature sensors to keep track of the tank’s temperature at different points.### Setup Details1. Hardware Used: - Fibaro Smart Implant: This tiny device was perfect for my needs. It’s compact and offers a lot of flexibility. - DS18B20 Sensors: These digital temperature sensors are reliable and affordable. I connected three of them to monitor different sections of the buffer tank.2. Configuration: - I followed the default setup guide for the Fibaro Smart Implant, which made the process straightforward. - The sensors are set to report temperature changes of at least 1°F, ensuring continuous monitoring without unnecessary updates.3. Integration: - The Fibaro Smart Implant seamlessly integrates with my existing smart home ecosystem. It sends temperature data to my Home Assistant setup, where I can view it on a custom dashboard.### **Why This Project?**I chose this project for a few reasons:- Energy Efficiency: Monitoring the buffer tank helps me optimize heating usage and reduce energy waste.- Peace of Mind: Knowing the tank’s temperature at all times gives me confidence that everything is running smoothly.- DIY Satisfaction: Completing this project was incredibly rewarding. It’s a great example of how small DIY projects can make a big difference.### Tips for Those InterestedIf you’re thinking about a similar project, here are a few tips:- Plan Ahead: Make sure all your sensors are connected before including the Fibaro Smart Implant. This ensures a smooth setup process.- Location Matters: Position your sensors strategically to get the most accurate readings.- Test Thoroughly: Spend some time testing the setup to ensure everything works as expected.### ConclusionThis project has been a fantastic addition to my smart home setup. It’s not only functional but also a great way to stay informed about my heating system. I’m already brainstorming other ways to use the Fibaro Smart Implant’s capabilities, like monitoring battery levels or adding more sensors.If you’ve got a similar DIY project in mind, I encourage you to give it a try! The satisfaction of seeing it come together is well worth the effort.Happy tinkering! ![]()
