Hey everyone, I wanted to share a fun DIY project I recently completed using a clap sensor. It’s been a journey of learning and problem-solving, and I’m excited to walk you through it!
I stumbled upon a clap sensor on AliExpress and decided to give it a try. At first, my soldering skills were pretty shaky, and the project didn’t go as planned. I ended up with a non-working sensor, which was pretty discouraging. But I didn’t give up!
After some research and investing in better soldering tools, I decided to try again. This time, I used an ESP D1 Mini, a USB cable, and some basic wiring. I also threw in a DHT22 sensor just for fun. The setup was pretty straightforward:
- Clap Sensor: Detects hand claps
- ESP D1 Mini: Acts as the brain of the project
- USB Cable: Powers everything up
- DHT22: Tracks temperature and humidity (just because I had one lying around!)
I integrated the clap sensor into my smart home ecosystem using MQTT and Node-RED. The project is super simple but has a cool factor that’s hard to resist. For example, I’ve programmed it so that clapping my hands turns on the lights or plays music. It’s especially entertaining for the kids, and I even use it to toggle devices from the comfort of my bathroom!
I built a small enclosure using a TS80 iron box, which wasn’t the prettiest, but it got the job done. The best part? The whole project cost less than $20, making it an affordable way to experiment with smart home tech.
This project isn’t perfect—it’s more of a novelty than a reliable control method. But it’s been a great learning experience, and I’m proud of how far I’ve come with my soldering skills!
If you’re looking for a fun weekend project, I’d definitely recommend giving this a try. It’s a great way to dip your toes into DIY smart home projects without breaking the bank. Happy clapping! ![]()
