DIY Fire Tablet Mount Using Recycled Materials
I recently embarked on a fun DIY project to mount my Amazon Fire 7 tablet, and I wanted to share my experience with the community. The goal was to create a simple, cost-effective solution that blends seamlessly into my home decor while keeping the tablet functional and easily accessible.
Project Background
I have two Fire tablets that I wanted to mount in different areas of my home. One was to replace a traditional light switch, and the other was to be placed above an existing switch I still use. The challenge was to find a mounting solution that was both secure and aesthetically pleasing without breaking the bank.
Materials and Tools
  • Old Credit Cards: I had a few expired credit cards lying around, which turned out to be perfect for this project.
  • Heat Gun: Used to shape the credit cards.
  • Vice: To hold the credit cards steady while heating.
  • Paint: To match the mount to my wall color.
  • Screws and Screwdriver: For attaching the mount to the wall.
The Process
  1. Shaping the Credit Cards: I started by clamping the credit cards in the vice. Using a heat gun, I carefully heated and bent the cards to form the desired shape. I found that shielding the heated area with a trowel helped achieve a smoother curve.
  2. Painting: Once the shapes were satisfactory, I applied a coat of paint to blend the mounts with my walls. This step was optional but added a polished finish.
  3. Mounting: For the tablet replacing the light switch, I partially unscrewed the cover plate to slide in the credit card mount. For the wall mount, I simply screwed the shaped credit card directly onto the wall.
  4. Final Touches: I ensured the tablets were charged and set up the necessary settings to keep them active. A quick tip: enabling the ‘Stay Awake’ option in the tablet’s settings prevents it from going to sleep while charging.
Results and Tips
This project turned out to be a huge success! The mounts are sturdy, and the tablets are perfectly positioned for easy access. Here are a few tips for anyone looking to try this:
  • Experiment with Shapes: Don’t be afraid to try different bends and curves. The credit cards are flexible and can be reshaped multiple times.
  • Safety First: When using a heat gun, always wear protective gloves and work in a well-ventilated area.
  • Customization: Consider adding decorative elements or personal touches to make the mounts unique to your space.
I’m thrilled with how this project turned out and can’t recommend it enough for anyone looking to repurpose old tech and materials. If you have any questions or need help troubleshooting, feel free to reach out! I’d love to see how others adapt this idea to fit their homes. Happy crafting! :hammer_and_wrench::sparkles:
