DIY Guide: Adding Extra USB and AC Ports to Your Floodlight Pro
Hey everyone! I wanted to share my experience with adding extra USB and AC ports to my Wyze Floodlight Pro. I know some of you might be wondering if it’s worth the effort, and I’m here to say it absolutely is!
Why Add Extra Ports?
I loved the original Wyze Floodlight V1 for its USB port, which I used for various gadgets. When I upgraded to the Floodlight Pro, I noticed the USB port was missing. While the Pro has amazing features like 2.5K resolution and local AI detection, I still wanted that extra port for flexibility. Whether it’s for redundancy, powering external devices, or just having more options, it’s a handy addition.
How I Did It
I stumbled upon a brilliant idea from the forums: using a weatherproof surge protector with built-in USB ports. This approach was much simpler and safer than trying to modify the floodlight itself. Here’s how I did it:
  1. Choosing the Right Surge Protector
    • Look for one that’s waterproof (IPx6 is ideal for heavy weather).
    • Ensure it has multiple USB-A ports and AC outlets.
    • I went with a compact model priced around $20, which fit perfectly under my eave.
  2. Installation Steps
    • Cut the power plug off the surge protector and strip the wires.
    • Wire the surge protector directly into the floodlight’s junction box.
    • Secure everything neatly to avoid any exposed wires.
  3. Mounting
    • I mounted the surge protector securely to the wall, ensuring it’s protected from the elements.
    • Now, I have extra USB and AC ports right where I need them, without the hassle of hiring an electrician!
Why This Solution Works
  • Cost-Effective: No need for expensive electrical work.
  • Flexible: Supports both USB devices and AC-powered gadgets.
  • Weatherproof: Perfect for outdoor use.
What I Use It For
  • Redundancy: I added an OG-Telephoto camera for backup during AWS outages.
  • Outdoor Lighting: Now I can power additional lights or gadgets without running new cables.
  • Convenience: Easy access to power for tools, phones, or other devices when working outside.
This project was surprisingly straightforward and has added so much value to my setup. If you’re thinking about doing something similar, I highly recommend it! Just make sure to follow safety guidelines and use the right tools.
Let me know if you have any questions or if you’ve tried something similar. Happy tinkering! :bulb::sparkles:
