Hey everyone, I wanted to share my recent project of creating DIY smart blinds for my living room. I’ve always been a fan of automation, but the high cost of commercial solutions really turned me off. So, I decided to take matters into my own hands and build something custom. Here’s my journey, complete with mistakes, solutions, and some tips for anyone looking to do something similar.### The GoalI wanted motorized roller shades that I could control via my SmartThings setup. The key was to keep costs low while ensuring reliability. I figured if I could source the right components, I could create something functional without breaking the bank.### Mistakes and Learning1. Initial Shade Purchase: I started with blackout shades from a local store, thinking they’d be a good fit. Turns out, the tubes were too small for the motors I planned to use. A lesson learned: always check the specifications of your motor and ensure the shades are compatible.2. Motor Choice: I tried a motor with a remote control, thinking it’d be handy. While it worked great, it couldn’t integrate with SmartThings without additional hardware. I ended up opting for a switch-type motor without the remote for better integration.### Materials and SetupHere’s what I ended up using:- Blinds: Signature blackout roller shades from Blinds.com with an aluminum tube.- Motor: A Rollerhouse 12V motor with a 25mm drive wheel.- Switch Module: Qubino Z-Wave Plus Flush Shutter DC Module.- Power Supply: 12V 2A adapter.- Switch: A DPDT toggle switch for manual control and programming.The setup involved attaching the motor to the shade’s tube, wiring everything up, and programming the motor’s limits. The key was ensuring the motor and tube fit snugly to prevent slipping.### Integration with SmartThingsAfter some research, I found a custom device handler for the Qubino module that allowed me to control the shades via SmartThings. It was a bit of a learning curve, but the ability to automate the shades based on sunrise/sunset times was worth it.### Tips for Success1. Plan Ahead: Measure everything carefully and ensure all components are compatible.2. Use the Right Tools: Don’t skimp on wiring and connectors. Quality components make a big difference in reliability.3. Test Thoroughly: Before fully committing, test the motor limits and ensure everything works smoothly.### Final ThoughtsThis project was a mix of frustration and triumph. While I hit some bumps along the way, the end result is a functional, cost-effective smart blind system that I’m really happy with. It’s also given me the confidence to tackle more complex DIY projects in the future.If anyone has questions or wants advice on similar projects, feel free to reach out! I’d love to help others avoid the mistakes I made.Cheers, [Your Name]
