Hey everyone! I wanted to share my journey with setting up a maintenance package for my smart home setup. It’s been a work in progress for months, but I finally got it just right, and I’m super excited to share the details with you all.The Inspiration I was inspired by some fantastic ideas from the community, particularly around GitHub integration and automating home assistant updates. I wanted something that would let me update my configuration from my laptop and push it to GitHub, or pull updates from GitHub right into my system. Plus, I wanted the ability to upgrade Home Assistant with just a button press—something reliable and foolproof.The Setup First off, I had to configure my GitHub account with SSH to avoid logging in every time I pushed an update. That was a bit of a learning curve, but once it was set up, it made everything smoother. Next, I focused on making GitHub the central hub for my configuration files. This means that every time I pull from GitHub, it overwrites my local files. It might sound risky, but it’s actually a lifesaver. If I mess up my local config, I can just pull the latest version from GitHub and everything’s back to normal—except for any untracked files like secrets, of course.The Challenges One hurdle I encountered was with bash scripts that required sudo privileges. I had to dive into the /etc/sudoers file to allow specific commands to run without a password. It was a bit intimidating at first, but it paid off in the end. Now, my scripts can run smoothly without any manual intervention.The Results Here’s what I ended up with: - Maintenance Mode: Disables notifications during updates to keep things quiet. - Restart HA: A clean restart using sudo systemctl restart. - Reboot Node-zero: A simple reboot command for my Raspberry Pi. - Upgrade HA and Restart: Automatically updates Home Assistant, pulls the latest custom UI, and restarts everything. - Pull from GitHub and Restart: Syncs my local config with the latest from GitHub. The Future I’m currently working on a step-by-step guide to make this process accessible to everyone. It’s a bit time-consuming, but I believe it’ll be worth it to help others set up their own maintenance systems.If anyone has tips or suggestions on how to improve this setup, I’d love to hear them! Also, if you’ve implemented something similar or have your own automation projects, please share—always great to learn from the community!Cheers to all the DIYers out there—let’s keep innovating and sharing our smart home hacks! ![]()
