Hey everyone, I wanted to share my recent DIY project with you all! After spending weeks researching and planning, I finally installed a sleek RGB LED strip in my living room. The goal was to create a customizable ambient lighting setup that could be controlled directly through Home Assistant. Here’s how it all went down:
The Setup
I decided to go with a 3-meter LED strip, opting for a 12V version with 60 RGBW pixels. I chose this setup because it offers smooth color transitions and excellent dimming capabilities—exactly what I was looking for. To keep things simple, I connected the strip directly to a Shelly Plug via a power adapter, allowing me to control it wirelessly through Home Assistant.
The Process
- Planning the Layout: I mapped out where the strip would go, ensuring it would wrap around the room seamlessly. I used double-sided tape to secure it to the baseboards, making sure it was evenly spaced.
- Wiring and Connections: Running the power and data cables was a bit tricky, but I managed to hide them neatly behind the furniture. The Shelly Plug made this part a breeze since it eliminated the need for complex wiring.
- Integration with Home Assistant: Setting up the LED strip in Home Assistant was straightforward. I used the
mqttplatform to create a custom switch entity, allowing me to control the strip through the frontend or even my voice assistant.
The Outcome
The results are absolutely stunning! I can now change the color scheme with a single tap, set up automated routines, and even integrate the strip with my music system for a synchronized light show. It’s amazing how a simple project like this can completely transform the ambiance of a room.
Lessons Learned
- Choose the Right Strip: RGBW strips are a great investment if you want precise color control and smooth transitions.
- Plan Your Wiring: Take the time to map out where your cables will go to avoid a messy setup.
- Leverage Smart Plugs: Devices like the Shelly Plug simplify the integration process and add an extra layer of convenience.
This project has been a fantastic way to dip my toes into DIY electronics and Home Assistant customization. It’s not only functional but also a lot of fun to play with. If you’re thinking about something similar, I highly recommend giving it a try!
Happy tinkering! ![]()
