DIY Smart Lighting Automation with Aqara Cube and Node-RED
I’m thrilled to share this innovative video by Technithusiast, showcasing how to create a smart lighting automation system using the Aqara Cube and Node-RED. This tutorial is perfect for those looking to delve into custom automation without relying on the Aqara Hub, demonstrating creativity and technical prowess.
In this detailed walkthrough, Technithusiast uses a ConBee USB stick to connect the Aqara Cube via Zigbee, bypassing the need for the Aqara Hub. The video guides viewers through setting up Node-RED flows to control lighting brightness based on cube rotations, even adding smart tolerances to prevent accidental triggers. This project is ideal for enthusiasts exploring Home Assistant integrations and custom automation solutions.
What are your thoughts on this DIY approach to smart lighting? Have you experimented with custom automation using Node-RED or similar tools? Share your experiences or challenges in the comments below!
