DIY Smart Lighting Project: Challenges and Solutions
As I embarked on setting up my new smart home, I decided to tackle a DIY smart lighting project. The goal was to install RGBIC Glide Wall Lights in my living room, aiming for a sleek and modern look. However, I quickly encountered an unexpected challenge that tested my patience and problem-solving skills.
The installation went smoothly, but when I tried adjusting the brightness using the app, I noticed something odd. No matter which DIY mode I selected, the brightness remained at 100%, even when I set it to 1%. This was perplexing, especially since the color and color temperature settings worked perfectly. I couldn’t help but feel a bit frustrated, wondering if I had made a mistake during the setup.
Determined to resolve the issue, I reached out to the manufacturer’s support team. After some back-and-forth, they suggested checking the firmware version of the lights. Sure enough, an update was available, and I followed the instructions to update the firmware. To my delight, the brightness adjustment issue was resolved, and everything worked as intended.
This experience taught me the importance of staying updated with firmware and reached out to the community to share my journey. It’s a reminder that even the most frustrating challenges can often be overcome with a bit of research and persistence.
For anyone undertaking a similar project, I recommend thoroughly checking the firmware and documentation before diving into more complex setups. It’s also a great opportunity to connect with others in the community who might have faced similar challenges. Happy DIY-ing! :bulb:
