After battling with traditional traps and their不便的维护,我决定升级我的老鼠陷阱。目标是创建一个与Alarm.com集成的智能老鼠陷阱,这样我就可以在手机上实时收到警报,而无需每天检查陷阱。The solution I came up with is基于一个Rat Zapper电子老鼠陷阱,它有一个警报端口,可以连接到2.5mm音频插头。我使用了一个Honeywell 5817传感器,将其配置为“normally open”模式,并将其连接到我的2GIG安全面板。这样,当老鼠触发陷阱时,传感器会发送一个信号到Alarm.com,面板会显示“INTRUSION TERMINATED”。The setup was a bit tricky at first, but with some research and trial and error, everything worked out. I was able to successfully integrate the trap into my existing security system, and now I receive notifications whenever a mouse is caught. This has been a game-changer for me, especially since I live in a rural area where mice are a common issue.I’d like to share a few tips for anyone looking to undertake a similar project:1. Research Compatibility:确保使用的传感器和安全面板兼容。Honeywell 5817是一个不错的选择,因为它支持多种配置。2. Test Each Component Individually:在将所有东西连接到安全系统之前,先测试陷阱和传感器的工作情况。3. Use High-Quality Cables and Adapters:劣质的电缆或适配器可能会导致连接问题,影响整体性能。4. Document Everything:记录下每一步的设置过程,这样在遇到问题时可以轻松回溯并排除故障。Overall, this DIY project has been incredibly rewarding. It combines my love for tinkering with technology and solving practical problems around the house. If you’re looking for a fun and useful way to enhance your home security, I highly recommend giving this a try
