Recently, I embarked on a DIY project to transform a regular three-hole power strip into a smart device compatible with my Homey system. The goal was to monitor energy usage and control the connected devices remotely. Here’s how I did it and what I learned along the way.
Project Overview
I decided to use a Shelly Plus 1PM module for its Wi-Fi connectivity and built-in energy monitoring capabilities. The process involved modifying the existing power strip to integrate the Shelly module seamlessly. While I had some initial concerns about handling electrical components, the step-by-step guide I followed made the process manageable.
The Process
Planning and Preparation: I started by gathering all necessary components, including the Shelly module, a 3D-printed housing, and the required tools. Safety was a top priority, so I made sure to disconnect the power strip before making any electrical connections.
Wiring and Installation: The most critical part was connecting the Shelly module to the power strip. I carefully stripped the wires and connected them according to the instructions. It was a bit nerve-wracking, but taking it one step at a time helped me stay focused.
Testing: After assembling everything, I tested the setup by plugging in the power strip. The Shelly module quickly connected to my home network, and I could monitor energy usage and control the outlets via the Homey app. It was incredibly satisfying to see everything work perfectly!
Challenges and Lessons Learned
- Precision is Key: Handling electrical connections requires patience and precision. Any mistake could lead to serious issues, so I made sure to double-check each connection.
- Documentation is Essential: The detailed guide I followed was invaluable. Without it, I might have gotten lost during the wiring process.
- Safety First: Working with electricity is inherently risky, so I prioritized safety at every step. Disconnecting the power strip beforehand was a crucial precaution.
This DIY project was a fantastic way to enhance my home automation setup. It not only added functionality but also gave me a sense of accomplishment. If you’re considering a similar project, I highly recommend starting with a clear plan, ensuring all safety measures are in place, and taking your time with each step.
If you have any questions or tips for future projects, feel free to share them below! Happy tinkering! ![]()
