Hey everyone! I’ve been diving into DIY smart home projects lately, and I wanted to share my latest endeavor—a custom smart smoke sensor setup using Home Assistant. If you’re into tinkering with hardware and automation, this might be right up your alley!
The Setup
I decided to go with the D1 Mini ESP32 module paired with an MQ-2 smoke and gas sensor. The combination is surprisingly affordable and effective. Here’s what I used:
- D1 Mini ESP32: Great for IoT projects and super easy to program.
- MQ-2 Sensor: Detects smoke and various gases, perfect for home safety.
- ESPHome: The perfect tool for setting up and managing ESP devices within Home Assistant.
The Process
- Hardware Assembly: Soldering the components together was straightforward. I followed a basic breadboard layout to keep things tidy.
- Firmware Configuration: Using ESPHome, I configured the sensor to report status updates every minute. It also triggers alerts if smoke is detected.
- Integration with Home Assistant: Setting up the sensor within Home Assistant was a breeze. I used the built-in ESPHome integration to add the sensor to my dashboard.
Tips for Success
- Placement Matters: I mounted my sensor in the kitchen, near the stove. It’s high enough to avoid false triggers but still within range of potential hazards.
- Test Alarms: Before relying on the sensor, I tested it with a controlled smoke source (like a candle) to ensure it works as expected.
- Automation Fun: I linked the smoke sensor to my smart lights and notifications. If smoke is detected, my lights flash red, and I get a push notification on my phone.
The Results
This project has given me peace of mind knowing my home is better protected. It’s also been a fantastic learning experience, especially for those of us new to ESP devices and DIY electronics.
Looking Forward
I’m already brainstorming my next project—maybe a smart water leak detector? If anyone has tips or suggestions, I’d love to hear them!
Stay safe and keep tinkering! ![]()
