DIY Smart Switch Project: Combining ESP32-CAM, Buttons, and Sensors
I recently undertook an exciting DIY project to create a smart wall switch that integrates an ESP32-CAM camera, two momentary buttons, and a DHT11 sensor for monitoring temperature and humidity. This project was inspired by my desire to enhance my home automation setup while also exploring the capabilities of ESP32 and Home Assistant integration.
Project Overview
The goal was to design a wall switch that not only controls lighting but also serves as a surveillance camera and environmental monitor. I decided to use the ESP32-CAM module for its built-in camera functionality, which allows for motion detection and video surveillance. The two buttons were implemented to trigger specific automation actions, such as turning on lights or adjusting settings. The DHT11 sensor was added to monitor environmental conditions, providing valuable data for home monitoring systems.
Components and Setup
I sourced the components from various online retailers, including the ESP32-CAM, momentary buttons, and DHT11 sensor. The design was prototyped using ESPHome for configuration, which provided a seamless integration with Home Assistant. The ESP32-CAM was configured to act as a camera module, while the buttons were programmed to send commands to Home Assistant upon activation.
Challenges and Solutions
One of the initial challenges was ensuring stable communication between the ESP32-CAM and Home Assistant. I encountered issues with camera feed latency and had to adjust the camera settings to optimize performance. Additionally, I needed to fine-tune the button debounce settings to prevent unintended trigger actions.
To address these issues, I reviewed the ESPHome documentation and sought advice from the Home Assistant community forums. Through trial and error, I was able to stabilize the camera feed and refine the button functionality.
The integration with Home Assistant was a key aspect of this project. I configured the ESP32-CAM as a camera entity, allowing me to view live feeds and recorded footage directly within Home Assistant. The buttons were set up as input boolean entities, enabling them to trigger custom automation rules. The DHT11 sensor was integrated into the system to provide real-time temperature and humidity data, which I then used to create environmental monitoring dashboards.
Results and Reflections
The final result exceeded my expectations. The smart switch now seamlessly integrates into my home automation ecosystem, providing a versatile and functional addition to my setup. The ability to control lighting, monitor my environment, and access live camera feeds from a single device has significantly enhanced my smart home experience.
This project was a rewarding learning experience, allowing me to deepen my understanding of ESP32 programming, Home Assistant integration, and DIY electronics. I am excited to continue exploring the capabilities of ESP32 and expand my smart home setup with similar projects in the future.
