DIY Smart Thermostat Project – Success and Questions!
Hey everyone, I wanted to share my recent DIY smart thermostat project and get your thoughts on potential improvements or troubleshooting tips! :rocket:
After weeks of research and tinkering, I finally got my DIY smart thermostat up and running using a NodeMCU, DHT22 sensor, and some relays. It’s been a fantastic learning experience, and I’m thrilled to see it working seamlessly with Home Assistant! :tada:
Here’s a quick rundown of the setup:
  • NodeMCU with Tasmota firmware for control
  • DHT22 sensor for accurate temperature and humidity readings
  • Relays for AC, Heat, and Fan control
  • LED indicators for visual feedback during testing
The system now successfully integrates with Home Assistant, allowing me to control my HVAC system through the app. It’s been a joy to tweak the automations and watch everything come together. However, I’m curious about a few things:
  1. Optimizing the DHT22 sensor: While it’s working well, I’ve heard the DHT22 can sometimes be finicky. Any tips for ensuring consistent readings?
  2. Advanced automation ideas: I’d love to explore more sophisticated automations, like adaptive cooling based on historical data. Any suggestions?
  3. Safety precautions: I’m using LEDs for testing, but I’d like to ensure I’m following best practices for handling HVAC relays. Any safety tips?
I’d also love to hear if anyone has experience with similar setups or has tried integrating a DIY thermostat with Home Assistant. Your insights would be invaluable! :handshake:
Thanks in advance for your help and support! Let’s keep the DIY spirit alive! :bulb:
