DIY Sump Pump Monitoring Setup - My Experience and Tips
I recently embarked on a DIY project to monitor my sump pump, and I wanted to share my experience and some tips for anyone considering a similar setup.
The Problem
Living in an area prone to heavy rains, I’ve always been concerned about my sump pump. While I had moisture detectors, I was experiencing false alarms, which was both frustrating and time-consuming.
The Solution
I decided to set up a sump pump camera with motion detection and integrate it with my smart home system. Here’s what I did:
  1. Camera Setup: I installed a Wyze camera with night vision to monitor the sump pit 24/7. The camera is mounted on a sturdy board secured to bricks to prevent it from tipping over.
  2. Smart Lighting: To illuminate the pit when needed, I used an LED clamp light controlled by a smart switch. This allows me to turn the light on or off remotely, which is especially handy for checking the pit without physically going there.
  3. Motion Alerts: I configured the camera to send motion alerts to my Apple Watch. This way, I’m immediately notified if the sump pump runs or if there’s any unusual activity.
  4. Integration: The entire setup is integrated with Home Assistant, allowing me to monitor and control everything from a single interface.
Tips and Tricks
  • Mounting: Ensure your camera is securely mounted to avoid any accidental movements, especially if the sump pit is prone to water fluctuations.
  • Lighting: Use a clamp light with a flexible arm for better positioning. The smart switch allows for easy on/off control without needing to physically adjust the light.
  • Motion Detection Settings: Fine-tune the motion detection settings on your camera to reduce false alarms. I found that adjusting the sensitivity and setting up a schedule helped significantly.
  • Integration with Smart Home: Take advantage of your smart home ecosystem. I use automation rules to send alerts and even trigger other actions, like sending a notification to my family if the pump runs during the night.
Conclusion
This project has given me peace of mind, knowing that I can monitor my sump pump remotely and receive immediate alerts if anything goes wrong. It’s a relatively inexpensive setup that has proven to be incredibly useful. If you’re considering something similar, I highly recommend starting with a camera and smart lighting, then gradually integrating more features as you become comfortable.
Would love to hear about others’ experiences with sump pump monitoring or any additional tips you might have!
