Hey everyone, I wanted to share a fun DIY project I recently completed that combines my love for coffee and smart home automation. I’ve always wanted a WiFi-enabled coffee machine, and after some research and experimentation, I managed to create a custom solution using my Keurig coffee maker. Here’s how I did it:
The Goal
I wanted to be able to start my Keurig coffee maker using voice commands through my smart home system. While there are some promising products on the market, like the Spinn coffee maker, I wasn’t willing to spend $300 for one. So, I decided to take matters into my own hands.
The Setup
I decided to use Snips on a Raspberry Pi 3 for voice processing, Home Assistant for automation, and a NodeMCU WiFi microcontroller to handle the hardware integration. The NodeMCU sends MQTT messages to Home Assistant, which then triggers the coffee-making process.
The Hardware
- Keurig Coffee Maker: The base unit I wanted to modify.
- NodeMCU ESP8266: To handle the WiFi communication and relay control.
- Solenoid: To press the power button on the Keurig.
- Light Dependent Resistors (LDRs): To monitor the status of the coffee maker (power, heat, water levels).
The Process
- Initial Research: I looked into taking apart the Keurig to see if I could add WiFi directly, but it proved too complicated and risky. Instead, I opted for a simpler solution by controlling the power button.
- Hardware Integration: I mounted the NodeMCU and solenoid on top of the Keurig. The solenoid is positioned to press the power button, while the LDRs monitor the LED indicators on the coffee maker.
- Software Configuration: I set up Snips on the Raspberry Pi to handle voice commands, which then send MQTT messages to Home Assistant. Home Assistant processes the request and sends the appropriate command to the NodeMCU to activate the solenoid.
- Testing and Iteration: I tested the system extensively to ensure reliability. The solenoid needed precise calibration to apply just the right amount of force to press the button without damaging the Keurig.
The Results
After several weeks of tweaking and testing, the system works perfectly! I can now say, “Hey, make me a coffee,” and within seconds, my Keurig starts brewing my morning cup. The LDRs provide feedback on the coffee maker’s status, which I display in Home Assistant for monitoring.
Challenges and Lessons Learned
- Precision in Mechanics: Getting the solenoid to press the button accurately was a challenge. I had to experiment with different spring tensions and mounting positions.
- Signal Noise: The LDRs were sensitive to ambient light, so I had to shield them properly to ensure accurate readings.
- Integration with Home Assistant: Setting up the MQTT integration and automations took some time, but the Home Assistant community documentation was incredibly helpful.
Future Plans
Now that the basic functionality is working, I plan to add more features. My next goal is to automate the brewing process based on my wake-up schedule. I also want to add a cup warmer to keep my coffee hot if I hit snooze on the alarm. Maybe even a robot arm to load the coffee pods automatically—though that might be a bit ambitious!
This project was a fantastic way to combine my interests in DIY electronics and smart home automation. It’s incredibly satisfying to have a custom solution that perfectly fits my needs. If anyone has questions or wants to share their own smart coffee projects, I’d love to hear about them!
Cheers,
