DIY Wyze V3 Glare Shield: A Step-by-Step Guide
Hey everyone, I’ve been diving into some fun DIY projects lately, and I wanted to share one that’s been particularly rewarding. A while back, I noticed that my Wyze V3 camera was suffering from glare, especially when the sun hit it at certain angles. It was making it hard to get clear footage, so I decided to tackle the problem head-on. Here’s how I did it!
The Inspiration
I came across a post in the forums where someone had created a custom glare shield using a square tube mount. It looked pretty effective, but I wanted to take it a step further. I decided to design a full-section shield that wouldn’t require removing the camera’s base, keeping everything intact and secure.
The Process
  1. Materials Needed: I gathered some basic materials—square tubing, a saw, a drill, some screws, and a bit of sandpaper. I also printed out a detailed PDF template to guide me through the measurements and cuts.
  2. Designing the Shield: Using the template, I marked out the sections I needed to cut. The key was ensuring the shield wouldn’t block the camera’s field of view while still providing adequate protection from glare.
  3. Assembly: Once all the pieces were cut and sanded, I drilled some holes and attached the shield to the window mount. I made sure everything was snug but not too tight, allowing for easy adjustments if needed.
  4. Testing: After securing the shield, I tested it out in different lighting conditions. The results were amazing! The glare was significantly reduced, and the camera’s field of view wasn’t compromised at all.
The Outcome
Not only does this shield protect the camera from glare, but it also adds a bit of a custom touch to my setup. It’s been a great learning experience, and I’m proud of how it turned out!
A Tip for Others
If you’re thinking about tackling a similar project, start with a temporary mount to test your design. It’s a low-commitment way to see if the shield works for your setup before making it permanent.
I’d love to hear if anyone else has tried something like this or has tips for improving the design. Let’s keep the DIY spirit alive! :blush:
