Does the Floor Lamp T1 need an Aqara hub for full controls?
I saw the Floor Lamp T1 in Aqara’s new lighting announcement and I’m trying to understand how it will connect. Will it work directly with Apple Home through Matter over Thread, or is an Aqara hub required for the full color controls, zones, and scenes in Aqara Home?
If a hub is required, will the Hub M100 support everything the lamp can do, or would the M3 be needed?
Thanks!
I’m not sure if anyone can fully give product details out since it’s not launched yet (anyone who has access would be under NDA).
That said, some general thoughts. Apple Home supports full whites and colors for lights generally. This is usually not a limitation. On/Off, Dimming, Changing Colors or white tones, or even Adaptive Lighting should work based on precedent.
Other features like addressable LED zones, speciality scenes/animations/music sync do not have a comparable control set in Apple Home to map to.
How we often get these advanced features working in Apple Home is through Matter scene & signal sync, which does require a hub, and the M100 should support it. This just allows you to take features from Aqara, place them into scenes or trigger switches, and share with any downstream matter ecosystem.
Hope that helps a little.
