Hi why is my Aqara door hub camera g410 occasionally have lost connection issues, I am having it now
I don’t have the G410, but I can give you a few things to check. Is it on batteries or wired? On batteries the doorbell sleeps a lot, so a weak signal is worse. In the app you can see the Wi-Fi signal, check it with the door closed. Also, if your router has the same name for 2.4 and 5 GHz, you can try a separate 2.4 GHz network just for the doorbell.
The bot opened a ticket for you, so send them the firmware version and the times when it disconnected. With that they can check the logs.
