Doorbell G4- Wired power options
So I have the car G4 doorbell. I was looking for ways to DIY power to the camera without having to plug it in. I live in an apartment in New York and in the building that really has some thieves running about stealing packages, etc. My door is next to an inner outlet inside of my home. Is there a way to use a relay switch with that wire so that I can create power for the camera yet? Also turn the light switch inside into a smart switch?
Hello.
For the G4 power supply, you will need to use a step-down transformer with an output voltage of 10+24 volts (1.5+2A).
To make a smart switch, use the T2 relay. Just keep in mind that the Aqara gateway is required for the relay to work.
Thank you! I do have an Aqara cam hub. I’ll keep you all posted. All this is new for me. Lots of options, figuring it out step by step.
