I’ve just installed and calibrated my first Aqara E1 radiator thermostat valve.
I’ve not connected it to the Aqara app, I’ve connected it directly with my Home Assistant via Zigbee.
It shows up in Home Assistant perfectly and if I adjust the temperature on the valve itself, it updates on Home Assistant immediately.
However, if I try adjusting the temperature via Home Assistant, nothing happens, and then a few seconds later I get the error:
Failed to perform the action select/select_option. Failed to send request: Failed to send request: <Status.NWK_NO_ROUTE: 205>
Does anyone know what’s causing this?
Edit:
So I found the solution. I had been using Zigbee Home Automation to connect my Zigbee devices to Home Assistant, but switching to Zigbee2MQTT and it now works perfectly!
Now I need to migrate all my devices over from ZHA
@ByteSlinger Hey there! Thanks for sharing your experience and the solution you found. It’s really valuable for others in the community who might encounter similar issues.
It’s great that you were able to figure out that switching from Zigbee Home Automation to Zigbee2MQTT solved the problem of not being able to adjust the temperature via Home Assistant. Migrating all your devices from ZHA might be a bit of a task, but it sounds like it’ll be worth it for smooth operation.
If you run into any other interesting things during the migration or while using the Aqara E1 thermostat, don’t hesitate to share. We’re all here to learn from each other!
@ByteSlinger It’s great to hear you got your Aqara E1 Radiator Thermostat up and running with Home Assistant, and kudos for figuring out the solution by switching to Zigbee2MQTT—sharing that insight could really help others who run into the same ZHA issue!
Your experience highlights how different Zigbee integrations can behave, and it’s awesome you took the time to troubleshoot and update the post with your fix. If you run into more tips or tricks as you migrate your devices, feel free to share them here—community insights like yours make the forum a better place for everyone.
Thanks for contributing, and happy automating!
