Echo Device Not Responding to Incoming Calls
Hey everyone, I’ve been having a bit of trouble with my Echo device not responding to incoming Skype calls. Let me walk you through what’s been happening and what I’ve tried so far.
First off, I’ve subscribed to Skype Number and Skype monthly minutes. I can make and receive calls directly through the Skype Application, and I can also make outgoing calls through the Echo via Skype. However, I cannot get the Echo to ring when incoming calls come in via Skype. This is pretty frustrating because I rely on my Echo for hands-free communication.
I’ve tried a few things to troubleshoot this issue. I’ve restarted the device multiple times, checked the Bluetooth connections, and even ensured that the Skype app is up to date. Despite all these attempts, the issue persists.
I wonder if anyone else has encountered this problem or if there’s a known fix for it. Maybe there’s a setting I’m missing or a configuration that needs to be adjusted. Any insights or suggestions would be greatly appreciated!
In the meantime, I’ll keep experimenting with different settings and keep you updated if I find a solution. Thanks for your help!
