In the ever-evolving landscape of smart home automation, optimizing data management is crucial for both functionality and efficiency. I recently faced a challenge with my indoor hydrangea plant’s soil moisture sensor, which generated rapid and fluctuating data. This led to excessive data points being sent to Home Assistant, consuming unnecessary disk space.
To address this, I implemented a sliding window moving average filter to smooth the raw data. This not only stabilized the readings but also allowed me to send smoothed data to Home Assistant at a much slower interval (every 5 minutes) while maintaining a 1-second update frequency locally for quick pump control. Here’s how I achieved it:
Sensor Configuration: I used a simple metal soil moisture sensor connected to an ESP8266. The sensor’s raw output was noisy, so I applied a sliding window average with a window size of 10 readings. This significantly reduced noise and provided stable moisture readings.
Automation Logic: The pump turns on at 42% moisture and off at 55%, running for 10-15 seconds each cycle. This is handled locally on the ESP8266 to ensure fast response times, even if Home Assistant is offline.
Data Management: To prevent data overload in Home Assistant, I configured the sensor to send data every 5 minutes. This was done by adjusting the
send_everyparameter in the filter settings while keeping theupdate_intervalat 1 second for local processing. -
Code Snippet: Here’s a simplified version of the ESP8266 configuration:
yaml
sensor:
- platform: adc
pin: A0
filters:- sliding_window_moving_average:
window_size: 10
send_every: 5
lambda: |
return x;
This setup ensures that my hydrangea receives consistent watering without overwhelming my system with data. I’d love to hear how others optimize their smart home systems for efficiency and performance!
