Efficient Solar Solution for Wyze Outdoor Cameras
I’ve been exploring ways to power my outdoor security cameras sustainably, and I’m thrilled to share a solution that’s been working perfectly for the past few weeks. Many of you might be familiar with the challenge of keeping outdoor cameras powered, especially in areas with limited access to electricity. After some research and experimentation, I found a cost-effective and eco-friendly solution using a single solar panel to power two Wyze Outdoor V1/V2 cameras. Here’s how I did it and how you can replicate it:
Materials Needed:
  • 2x Wyze Outdoor V1/V2 Cameras
  • Wyze or Wasserstein Solar Panel
  • ELECTOP Micro USB Female to 2 Micro USB Male Splitter Cable
  • Black Thick Electrical Tape
  • PEF Mount for Wyze Cam Outdoor
  • Medium Drill Bit and Drill
**Setup Process:**1. Solar Panel Activation: The solar panel needs a full week of direct sunlight to charge its internal battery fully. This ensures it can provide consistent power to both cameras.
  1. Cable Management: Using the Micro USB splitter, I connected both cameras to the solar panel. This setup not only powers both devices simultaneously but also ensures a weatherproof seal.
  2. Mounting: I used the PEF mount to secure the solar panel and cameras. Drilling a small hole allowed me to route the cables neatly, ensuring a clean and secure installation.
  3. Sealing: To prevent water ingress, I applied silicone sealant around the drilled hole and used electrical tape to secure the cable connections.
**Results:**This setup has been running smoothly, providing uninterrupted power to both cameras. The cameras are now fully integrated into my smart home system, offering reliable surveillance without the need for frequent battery changes or running extension cords.
Why This Solution Works:- Cost-Effective: Utilizing a single solar panel for multiple devices reduces upfront costs and long-term energy expenses.
  • Eco-Friendly: Solar power significantly reduces the environmental impact compared to traditional power sources.
  • Low Maintenance: Once installed, this system requires minimal upkeep, making it ideal for long-term use.
If you’re considering solar power for your outdoor devices, I highly recommend exploring this setup. It’s a win-win for functionality, sustainability, and ease of use.
Feel free to reach out in the comments if you have any questions or need clarification on any step! Happy tinkering! :rocket:
