Hey everyone! I wanted to share my recent success in integrating my Xiaomi vacuum cleaner into my smart home setup. It’s been a game-changer for keeping my home tidy without lifting a finger. Here’s how I did it and how you can too!
The Goal:
I wanted to create a seamless system where I could trigger my vacuum to clean specific rooms with just a tap on my phone or through voice commands. After some research, I decided to use HomeKit and Lovelace to achieve this.
The Setup:
I configured my vacuum to clean two specific rooms using segment cleaning. Here’s a simplified version of what I added to my configuration.yaml file:
yaml
switch:
- platform: template
switches:
clean_kitchen_livingroom:
turn_on:
data:
entity_id: vacuum.xiaomi_vacuum_cleaner
service: xiaomi_miio.vacuum_clean_segment
segment: [16, 17] # Codes for my kitchen and living room
turn_off:
service: vacuum.return_to_base
data:
The Result:
Now, I have a neat switch in both HomeKit and Lovelace that starts the vacuum automatically when I tap it. It cleans the specified rooms and then returns to its base, ready for the next task. It’s incredibly convenient, especially on busy days when I don’t have time to manually operate the vacuum.
Tips for Others:
- Understand Your Vacuum’s Segments: Make sure you know the segment codes for your specific rooms. This ensures the vacuum knows exactly where to go.
- Test Thoroughly: Before relying on it fully, test the automation a few times to ensure it works as expected.
- Combine with Automations: You can even set this up to trigger automatically based on your schedule or other sensors, like motion detectors.
Final Thoughts:
This integration has been a fantastic addition to my smart home setup. It’s a small but meaningful way to make daily life easier. If you’re looking to add more automation to your home, I highly recommend exploring your vacuum cleaner’s capabilities—it might just be the next big thing in your smart home journey!
Feel free to reach out if you have questions or need help setting this up. Happy cleaning! ![]()
