Enhancing Home Automation for Dementia Care
I’ve been exploring how Home Assistant can make a meaningful difference for a family member with dementia. The idea is to simplify their interaction with technology, ensuring it’s intuitive and accessible. My primary goal is to create a one-touch remote for their favorite Sky TV channels using the Sky Remote integration. Beyond entertainment, I also want to integrate monitoring and possibly CCTV for safety, though that’s still in the planning phase.
I’ve set up an old Samsung Galaxy Tab to serve as the interface, and Fully Kiosk seems like the perfect solution for a seamless experience. The challenge has been configuring the tablet to boot straight into the desired dashboard. I’ve been experimenting with timed startup and shutdown scripts, but it’s a bit of a learning curve. I’ve installed Home Assistant on the tablet and set Fully Kiosk to launch the app automatically. The next step is ensuring it navigates directly to the pre-configured dashboard without any user input.
While I’ve encountered some hiccups, like ensuring the tablet boots up reliably and the dashboard loads without issues, the progress is encouraging. I’ve also been researching how to remotely access the system for troubleshooting, which is crucial given the setup’s location. The community’s resources have been invaluable, and I’m hopeful that with some more tweaking, this project will provide a much-needed assistive tool for daily life.
For anyone looking to integrate similar solutions, I’d recommend starting with a clear use case and testing each component thoroughly before full deployment. It’s a rewarding project, both in terms of technical learning and the positive impact it can have on quality of life.
