ESPHome Automation Tips and Experiences
Hey everyone, I wanted to share some of my recent experiences with ESPHome and automation. I’ve been diving into creating small, practical automations around my home, and it’s been a lot of fun. Here are a couple of projects I’ve worked on and some tips I’ve picked up along the way.
1. Pet Feeding Reminder with ESPHome
One of my favorite projects has been creating a pet feeding reminder using ESPHome. My fish needed to be fed once every 24 hours, and I often forgot. So, I set up a NodeMCU with two WS2811 pixels and a button. The script I wrote keeps the light green for 16 hours, then fades to red over the next 8 hours as a visual reminder. It’s been working perfectly!
Here’s a quick overview of the setup:
  • Hardware: NodeMCU, WS2811 pixels, and a button.
  • Software: ESPHome script with a fade loop and reset functionality.
If anyone has suggestions on how to make this even more user-friendly, I’d love to hear them!
2. Automating TV Shutdown with Zigbee Button
Another project I’ve been working on is automating the shutdown of my TV using a Zigbee button. The idea is simple: press the button to turn off the TV. But I wanted to ensure it only worked when the TV was on to avoid accidentally turning it on.
Here’s what I did:
  • Setup: Configured the Zigbee button to trigger an automation.
  • Condition: Checked if the TV was on before executing the shutdown command.
  • Issue: The automation still triggered the IR command even when the TV was off, which turned it on instead. I’m still figuring out why the condition isn’t working as expected.
If anyone has experience with similar automations or knows why the condition might not be working, please share your insights!
Tips and Tricks
  • Documentation: I’ve found that diving into the ESPHome documentation is crucial, even if it seems overwhelming at first. The community examples are a goldmine.
  • Testing: Always test your automations in a controlled environment before relying on them fully. It helps catch issues early.
  • Community Support: Don’t hesitate to reach out to the community for help. I’ve been amazed by how supportive everyone is.
Looking Ahead
I’m planning to explore more with ESPHome, maybe even setting up a small automation hub. If anyone has recommendations on what to try next or any common pitfalls to avoid, I’d appreciate the advice.
Thanks for reading, and happy automating! :rocket:
