ESPHome Dimmer Multi-Click Functionality
Hi everyone,
I recently set up an ESPHome-based Treatlife DS01C dimmer in my living room, and I must say, it’s been a fantastic addition to my smart home setup. The ability to control the dimmer through voice commands and the Home Assistant interface has made my evenings much more comfortable. However, there was one feature I was particularly excited about: the multi-click functionality.
At first, I was really looking forward to using the on_multi_click feature to create some custom scenes. For example, a single click for 50% brightness, double click for full brightness, and triple click to turn off the lights entirely. I thought this would add a nice touch of elegance to my setup.
But here’s the catch—I couldn’t get it to work. No matter how I configured the YAML file, the multi-click feature just wouldn’t trigger the actions I set up. I started to wonder if there was a hardware limitation preventing this functionality from working as intended. Maybe the dimmer’s firmware didn’t support it, or perhaps I was missing something in the configuration.
After some research and reaching out to the community, I found that I wasn’t alone in this struggle. Several users reported similar issues, and it seemed like the multi-click feature wasn’t as reliable as we all hoped. However, there was a silver lining—some users shared workarounds that involved using different click patterns or adjusting the timing parameters in the configuration.
I decided to give one of these workarounds a try. I adjusted the timing parameters in my on_multi_click configuration to match the exact click patterns I was using. To my delight, it worked! The dimmer now responds perfectly to single, double, and triple clicks, each triggering the corresponding scene I set up.
This experience taught me a valuable lesson about the importance of community support in the smart home ecosystem. Even when things don’t work out of the box, there’s usually a solution or a workaround that can be found with a bit of persistence and collaboration.
I’m really happy with how my ESPHome dimmer setup turned out. It’s a great example of how open-source projects like ESPHome can empower users to create truly customized and functional smart home solutions. If you’re considering adding an ESPHome-based dimmer to your setup, I highly recommend giving it a try—you might be pleasantly surprised by what you can achieve!
Cheers,
