I recently embarked on integrating my new Hörmann garage door into my Home Automation setup using ESPHome, and I must say, the experience has been quite rewarding. Let me share my journey and some tips for those considering a similar project.
The Setup
I started by connecting the Hörmann garage door to the Home Automation system via ESPHome. The key component here was the UAP1 connector box, which I plugged into the garage door motor. This box provided all the necessary inputs and outputs for my setup. I used the integrated 24V power supply to power the D1 Mini ESP32 via a voltage regulator, ensuring a stable power source.
For the control mechanism, I utilized relays connected to inputs to monitor the door’s states—whether it’s fully open or closed. I also set up two outputs using MOSFETs (specifically IRF530) to control the direction of the door. This setup allowed me to automate the garage door seamlessly within my smart home ecosystem.
Configuration Details
Here’s a snippet of my ESPHome configuration for reference:
yaml
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: ‘secret’
password: ‘secret’
Additional configurations including API, OTA, and GPIO setups
This configuration ensured that the garage door’s state was accurately monitored and controlled through Home Assistant.
Challenges and Solutions
One of the initial challenges was ensuring the correct wiring and configuration of the relays and MOSFETs. However, with some trial and error, I managed to get everything working smoothly. I also considered adding a DHT12 sensor to monitor the garage’s climate, which I plan to integrate in the near future.
Conclusion
Overall, integrating the Hörmann garage door with ESPHome has been a fantastic experience. It has enhanced my home automation setup significantly, and I look forward to expanding this project further. If you’re thinking of undertaking a similar project, I highly recommend exploring ESPHome for its flexibility and robustness. Happy automating!
