I recently set up my curtain control system using Esphome and MQTT, and I wanted to share my experience and some insights for anyone looking to do something similar. ![]()
The Setup
I have a pair of motorized curtains that I wanted to control seamlessly. The system uses binary sensors to detect button presses (up, down, stop) and relays to control the motors. Initially, I was manually controlling the switches, but I wanted to integrate MQTT for remote operation and automation. ![]()
The Journey
- MQTT Broker Configuration: I started by enabling the MQTT broker in my Esphome setup. It was surprising how easily it picked up two topics for my switches without any additional configuration!
- Binary Sensors vs. Switches: My goal wasn’t to control the switches directly but to simulate button presses through binary sensors. This approach ensures that the light goes on when the curtain moves and prevents both relays from activating simultaneously.
- Automation Magic: By integrating MQTT, I can now send commands to my curtain system from anywhere. For example, I have an automation that opens the curtains at sunrise and closes them at sunset.
Tips for Success
- MQTT Topic Naming: Use descriptive names for your MQTT topics to keep things organized. For example,
curtain/upandcurtain/downmake it clear what each command does.
- Testing: Before setting up complex automations, test each command individually to ensure everything works as expected.
- Security: Make sure your MQTT broker is secure, especially if it’s exposed to the internet. Use strong passwords and enable encryption if possible.
The Outcome
The integration has been seamless, and I’m thrilled with how responsive the system is. It’s not just about convenience; it’s about creating a harmonious smart home ecosystem where everything works together effortlessly. ![]()
If you’re considering a similar setup, I highly recommend exploring Esphome and MQTT. The combination of flexibility and reliability makes it a fantastic choice for DIY smart home projects. Happy tinkering! ![]()
