Eve MotionBlinds Retrofit Kit Review and Installation Experience
I’ve been eyeing the Eve MotionBlinds Retrofit Kit for a while now, and finally decided to give it a try last week. Let me share my experience and some tips for anyone considering this upgrade!
Installation Process
First off, the installation wasn’t as daunting as I initially feared. The kit requires a minimum tube diameter of 1.5 inches, which my existing blinds didn’t meet. I quickly sourced a piece of ABS plastic tubing, cut it to size, and re-rolled my blind material. This step was straightforward and only took about 30 minutes. The Eve kit itself was easy to install, with clear instructions that made the process smooth even for someone like me who isn’t a DIY expert.
Pairing the MotionBlinds with Home Assistant via the HomeKit Controller was seamless. I was up and running in just a few minutes. The integration is stable, and I appreciate the ability to control my blinds directly from the Eve app or through my voice assistant. It’s a great addition to my smart home setup!
Performance and Features
What truly impressed me is the performance. The blinds operate smoothly, and the battery life has been excellent—no need for frequent recharging. The programmable settings are a bonus, allowing me to set custom routines that adapt to my daily schedule. For instance, the blinds now gently open in the morning, letting in natural light to start my day.
Tips for Potential Buyers
If you’re considering this upgrade, here are a few tips:
  1. Measure your current blind tubes accurately to ensure the retrofit kit fits perfectly.
  2. Take your time with the tubing adjustment to avoid any misalignment.
  3. Familiarize yourself with the Eve app settings to get the most out of the features.
Overall, the Eve MotionBlinds Retrofit Kit has exceeded my expectations. It’s a worthwhile investment for anyone looking to add smart functionality to their existing window blinds. The integration with Home Assistant has taken my smart home experience to the next level, and I couldn’t be happier with the result!
