【Exclusive Trial】Aqara Radiator Thermostat W600 – Be the First to Try
Also lucky so looking forward to comparing the valves.
Thank you, I’ve successfully placed an order :blush:
Got my code and now ordered, thankyou so much!
Also received the code and placed my order, thank you! :smile:
I was lucky - happy to test the new W600 and compare it to the existing E1.
Thank you, Aqara!
I got lucky! Ordered them.I Will compare them with my E1
Did anyone receive the code?
Yep, I got it.
yep, 5 days ago :slight_smile:
In Sweden and been on the edge about getting thermostats since I have “fjärrvärme” which preferably is either on or off.
Thanks for the opportunity!
I wasnt lucky enough this time :slight_smile:
I just received my package. Can’t wait to test it :slight_smile:
Hello @AqaraOfficial do you maybe have any codes to share? I would really like to try the W600. thanks!
seems we have a similar issue like with the FP300 ([ISSUE] FP300 Unable to Switch to Zigbee Protocal - Download failed (Code: -1002) - #19 by KolloApple) - I assume the zigbee firmware is not available yet. Until I can switch over to zigbee, I won’t be able to test it as I don’t have a TBR (Thread Border Router) yet :frowning:
Are the packages already reaching you?
Yes, received mine today
Yes, mine also arrived today - very fast delivery; thank you, Aqara!
As pointed out, the setup fails entirely in the Aqara app for me. Neither Thread nor Zigbee (the latter might just be the firmware availability) worked.
Setup via Matter thru Apple Home was quick and easy.
Mine arrived too. Can’t wait sto tart testing it :blush:
Mine just arrived as well, I also want to use Zigbee and Homeassistant, but I cannot configure the Zigbee protocol with error code -1002
